Usually looking through the SMNP OID files I find OID entries for most of the settings via the WEB GUI but not all. I am looking to verify if there is or is not a working OID for the data listed on a subscriber module WEB GUI for SM Management Interface Access via Ethernet Port being "Enabled" or "Disabled". The one entry I was able to find which I am not sure if is this setting or not is listed as being deprecated or something like that. I currently run 16.2.1.
Can anyone verify for me if there is a SNMP queriable field for this particular setting as listed in the WEB GUI?
The OID you are looking for is "ethAccessEnable" (.1.3.6.1.4.1.161.19.3.2.1.76.0), in WHISP-SM-MIB.
