I have a perl script that uses SNMP to update newly-arrived SMs (as of right now, to v3.0.1 firmware) and then uses SNMP to load a default config.
But the default config load is failing on the radios I just got in - Force180s after update to 3.0.1.
Both files (ePMP-NonGPS_Synced-v3.0.1.tar.gz and ePMP-SMDefault-58.bin) are retrievable from the same server, the SM successfully retrieves and flashes the firmware.
But when it comes to the config load, it fails and I see "CAMBIUM-PMP80211-MIB::cambiumFullCfgRestoreError.0 Unpacking files error".
HOWEVER, if I load the exact same config file via web UI it works like a charm.
I'm going to try backing off to 2.6.2 and test, if successful then I'll alter my script to push 2.6.2, then config, then 3.0.1 I guess...
j
