Hello
Some discovered SM elements do not appear under Network > Define Networks > Discovered Elements window. I tried to Discover Elements manually under Edit > Discover Network Elements. I entered the SM’s Host IP address and clicked on OK. The “Discovering Network Elements” Window appears and completes the discovery successfully. The message I get is “Element (10.217.226.125) is currently in Discovered List of this network). But when I go to the Discovered List I don’t see anything there. Any clues anyone??
Reboot prizm server and check discovered list again, they’ll be there. Bug #10245 i think! I reboot prizm on a daily basis. Its a peice of crap and I wish we didn’t put so much money into it.
jmaysww wrote: Reboot prizm server and check discovered list again, they'll be there. Bug #10245 i think! I reboot prizm on a daily basis. Its a peice of crap and I wish we didn't put so much money into it.
Prizm is a hunk of junk, but I've never heard of having to reboot daily...
Running 3.1r7 on Red Hat Enterprise Linux with PostgreSQL and ~350 devices
The problem was fixed after I rebooted PRIZM. Thank you!!!
