Special Firmware - ePMP1000 Family - UNII-3 Upper
Dear , We need Special Firmware for Below Models of cambium : ePMP 1000 / Force 110 / Force 200 UNII-3 Upper: Frequency : 5.725 – 5.825 GHZ Transmit power : 100 mw
Please send me an email at alex.marcham@cambiumnetworks.com to discuss this request.
Alex
Dear , we found match Country Regulatory region Code but we have one Problem : “Installer” User can Change The Profile of Regulatory region ! Can you Limit it on “admin” Profile User ? It means when you login as “installer” you have Option to change Regulatory Profile and frequency But if you limit it to only change frequency and only “admin” can do all then it is fine . i think change and set regulatory should be a part of “admin” Profile not " Installer " . Match Region profile for countries has frequencies 5.7 & 5.8 : China is between 5740-5795 & 5800-5835 Maximum power is 20 dbm Iceland is between 5735-5795 & 5800-5865 Maximum power is 23 dbm Indonesia is between 5735-5795 & 5800-5815 Maximum power is 23 dbm New Zealand is 5735-5795 & 5800-5815 Maximum power is 23 dbm Qatar is between 5735-5785 & 5825-5865 Maximum power is 20 dbm Singapore is between 5740-5795 & 5800-5835 Maximum power is 18 dbm Vanuatu is between 5740-5795 & 5800-5835 Maximum power is 23 dbm Vietnam is between 5735-5795 & 5800-5840 Maximum power is 17 dbm
I believe the installer must be able to change the Regulatory Profile and frequency; they cannot really install it without these. I would suggest if this is a security issue, the administrator should change the installer password after each installer visit.
A more affective method is  to prevent the installer from having access to the AP and forcing the SM setting via the AP I can forsee no reason for an service install tech to have access to the AP. just my thoughts.
