Issues Fixed in SR 2.6.1:
Tracking |
Description / Workaround |
11156 |
On rare occasion, AP would detect a false radar hit on a DFS channel and stop transmission or move to an alternate channel (if configured). (Resolved in 2.6.1) |
11058 10780 10573 |
An issue related to DDR (memory) timing was exposed under cold ambient temperatures (below -5°C). This issue impacts only a specific set of MAC addresses that were manufactured. However, this issue is resolved by adjusting the timing of the DDR in software for stable operation, in all temperatures for which ePMP is rated for. (Resolved in 2.6.1) |
11106 11023 |
When using RADIUS authentication, SMs will randomly disconnect on a loaded sector. (Resolved in 2.6.1) |
11019 11005 |
AP may not transmit once the NOP timer expires after a DFS radar hit. (Resolved in 2.6.1) |
10958 11017 |
When AP is in TDD mode, it may crash under heavy traffic and interference. This is due to improper handling of packets in the software (Null pointer). (Resolved in 2.6.1) |
11107 10334 |
When using RADIUS authentication, on occasion AP will stop sending data to some SMs after re-authentication. (Resolved in 2.6.1) |
10488 |
On occasion in ePTP mode after several days of normal operation, the link drops and does not recover. A reboot of the Master or Slave is required to recover the link. (Resolved in 2.6.1) |
Known issues resident in SR2.6.1:
Tracking |
10907 |
When in AP WiFi mode and the SM connected is an 802.11a SM, the downlink throughput can be lower by 20%. |
10866 |
When switching channel bandwidth from 20 MHz to 5 MHz, the GUI will throw a warning that only Max Registration of 30 is allowed and saving the configuration will not be possible. Workaround is to edit the Max Registrations field under Configuration->Radio and save configuration. |
10846 |
After performing a factory reset using the physical reset button on the unit, User defined RADIUS certificates are not deleted from the device. Workaround it perform a factory reset through the GUI under Tools->Backup/Restore. |
10770 |
After a factory default through the GUI, user may not be able login into the GUI. Workaround is to reload the GUI in the browser. |
10704 |
When editing the MAC Addresses entries in the Wireless MAC Filtering table using the configuration file upload, care must be taken to ensure MAC address format integrity. The ePMP device will not validate the format. |
10702 |
When editing the Description field of the Wireless MAC Address Filtering table and saving, the wireless driver will be restarted resulting in the AP dropping all SMs and causing them to reregister. |
