Defect Fixes (System Release 3.1)
Tracking |
Description / Workaround |
11289 |
AP crash due to bad memory frame |
12601 12625 |
Force 200 ePTP reboot |
10581 |
High CPU utilization with GPS synchronization enabled |
11287 |
RADIUS: SM sends request with “anonymous” user name instead of configured MAC address |
11011 |
RADIUS: connection drops with pam.d error message |
12606 |
Unable to restore .bin configuration via SNMP |
12779 |
eDetect does not return interferer’s SSID via SNMP |
12229 |
Incorrect Transmitter Output Power validation for US country code/40MHz channel bandwidth configuration |
12448 |
False radar detection on DFS channels FCC1322 |
12012 |
Multicast: Network Group count not reported by Total Network Groups statistic |
11990 |
On rare occasion, ePTP Slave may stop passing traffic and require a reboot |
10756 |
Reported Downlink RSSI differs between AP and SM |
11456 |
On rare occasion, ePTP Slave may disconnect after a few days of normal operation |
12453 |
ePTP link latency unstable under interference |
10574 |
eDetect does not list more than 24 interferers |
12037 12404 |
It is not possible to configure SSID/Device Name with spaces |
12789 |
ePMP 2000: On occasion, after a reboot, the AP incorrectly pops up a notification that the Smart Antenna is disconnected even when it is connected and operating normally |
12684 |
When AP with spaces in its SSID is configured on the SM Preferred AP list, when the SM is downgraded to a released older than 3.1, the device may become unresponsive and may require a factory default |
12574 |
When SM switched to SA mode and configuration is saved, it is not possible to switch back to SM mode without rebooting the radio |
Known problems or limitations (System Release 3.1)
Tracking |
12594 |
On occasion, SM may fail to upgrade due to memory allocation. As a workaround, reboot the SM then restart the upgrade |
12409 |
With rare occurrence, SM scans without registration |
12709 |
ePMP 2000: Cannot factory default via power cycle sequence |
12792 |
Throughput Chart: Upon changing Throughput Measurement Period, control points (hover targets) not shown |
12814 |
GUI reports incorrect number of logged-in users |
12837 |
With certain configurations, GPS-synched software can be loaded onto Force 200 module |
12878 |
ePMP device reboots twice after factory default |
12874 |
5.2 GHz/5.4 GHz bands not supported for New Zealand country code |
12892 |
Wrong System Description in LLDP message from ePMP device |
12890 |
Web browser “back” button does not navigate to previous GUI page on ePMP device |
