Hopefully some of you MTik / ePMP guru’s can help me. I’m trying to SSH from a MikroTik 4011 into the Force 300c that is connected to it.
The ePMP has defaulted, so it’s ethernet’s IP is 192.168.0.2 currently. I have assigned 192.168.0.10/28 as a secondary IP address to the Ethernet of the MikroTik - and applied that - and I can ping from the MTik to the Force300 fine.
When I go to the MTik terminal, to /system, and then ‘ssh 192.168.0.2’, the F300 replies, and challenges for the password properly… but when I type in the default password, I get just…
ePMP command line interface *
…and that’s that. Nothing further – no ‘command prompt’ like I get when using PUTTY to log in directly to an ePMP.
