STAs disconnecting after adding LTE cell at same site
Hi All,
I have received below errors , we have add L2600 LTE cell in same site .SM getting time out after adding L2600 cells .once shut the L2600 cell .this issue is resolved .could you please support to check root cause for the failure .
Jul 11 07:59:15 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1270.660000] SM[58:c1:7a:4e:10:45] aid=4 disassociated. Reason: COMMUNICATION LOST
Jul 11 08:00:25 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1340.060000] SM[58:c1:7a:4e:0e:c3] aid=1 disassociated. Reason: COMMUNICATION LOST
Jul 11 08:01:07 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1382.140000] SM[00:04:56:e1:b7:ad] aid=2 disassociated. Reason: COMMUNICATION LOST
Jul 11 08:02:18 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1453.090000] SM[58:c1:7a:42:55:0d] aid=3 disassociated. Reason: COMMUNICATION LOST
Jul 11 08:02:46 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1481.230000] All STAs disassociated. IEEE80211_REASON_TDD_STOP (20)
Jul 11 08:07:48 MO0008_Wellawaya Dialog_PtMP_2 kernel: [ 1783.040000] All STAs disassociated. IEEE80211_REASON_TDD_STOP (20)
Jul 11 08:08:13 MO0008_Wellawaya Dialog_PtMP_2 DEVICE-AGENT[3845]: Accept failed
Jul 11 08:08:38 MO0008_Wellawaya Dialog_PtMP_2 DEVICE-AGENT[3845]: Accept failed
Jul 11 08:08:41 MO0008_Wellawaya Dialog_PtMP_2 DEVICE-AGENT[3845]: Accept failed
Jul 11 08:08:46 MO0008_Wellawaya Dialog_PtMP_2 DEVICE-AGENT[3845]: Accept failed
Hello @Dlahiru,
if you shutdown the new cell and it gets back to normal, it means the cell is an interferer!
You can try to change frequencies on both radios to find if they can coexist.
