Hi everyone, is it possible to run more than one static IP thru a SM at the same time?? I want to run 2 machines on the same network and have each running it’s own static IP address.
Terry
Vanderhoof, B.C.
Canada
If you are not using the NAT feature on Canopy SM, the unit is just a Layer2 switch (bridge). It will pass what you send in. So, yes.
