Stuck session identification
How to identify stuck sessions in large PMP 450 network deployed with wireless manager.
I am planning on writing a python script to fix this very issue tomorrow.  I will post the script when it is verified as working as expected ( should be by Friday or so, depending on the number of stuck sessions pop up to test against).
Step 1.  Query cnMaestro for SMs in a down state and store those in sms
Step 2.  Ping each item in sms.  If up, skip to next item.  If down, go to step 3
Step 3.  Boot SM off AP with the following code:
     http://community.cambiumnetworks.com/t5/PMP-450/Stuck-sessions/m-p/96621#M7255
I plan on running this every hour or so.
Hopefully the new 16 version eventually fixes this but we will not upgrade until it looks stable.  So a script will have to suffice for now.
Hi rnelson,
Have you considered using the "Ping Watchdog" feature as a workaround?
Balaji
Hi Balaji,
If I am understanding ping watch guard correctly, I would need to know in advance which SMs were getting stuck in order to monitor them.  Unfortunately the stuck SMs are difficult to predict.  Otherwise that looks like a great tool.
