i have got a problem the ap and sm can’t synchronise?
if the AP is connected to a CMM, make sure it is set to receive sync via power or timing port (depending on CMM type). If theres no CMM, make sure the AP is set to generate sync.
What is your setup? Remote AP? Then connect the AP’s Timing port to Timing port of the SM 1:1.
If you mean that your SM won’t register with your AP then maybe check out this post and see if it helps.
http://motorola.canopywireless.com/supp … php?t=1981
