Does Cambium make avaialble T/I curves for the 11GHz PTP800 product line?
The LINKPlanner software provides lots of information on the design of a link, including attenuation. Find out more about LINKPlanner here.
Thanks. I get PCN's daily and some bear doing interference calculations as related to our existing hops. You're right though, forgot about the interference box in LinkPlanner. That makes the interference calc quick and easy.
