TDD Issue on Point-to-Point Link with Two Force300csm
We have a PtP link with Force300csm radios and 27dBi Ultradish RFElement antennas with very good parameters and good airflow.
The problem we encountered is the following:
When we use PTP TDD on the link, the speed tests do not exceed 25M.
When we use ePTP on the link, the speed tests already exceed 60M and 80M.
All firmware has been tested from 4.8.1 (which was the most stable) to 5.10.0.
Has anyone had the same problem? What solution was found?
