Hi, I have been testing caopy with web access and now wanted to test it with telephone service.
Can someone give me some direction on where to find info.
Bascially, I wanted to test from within our office to a remote phone in a vehicle with and AP.
Explain a little more about what you’re trying to accomplish… and why. I’m confused about what use you would make of the phone connection.
Are you wanting to create a setup that allows you to dial into a remote AP when connectivity is lost? If so, what do you want to do when you’re dialed in: reboot, power cycle, check stats?
I want to connect a phone line from jack to SM then to AP and phone line to phone jack
Multitech makes some single or multi line voip adapters that can talk to each other. I have used the mvp130 across canopy and had real good luck.
http://www.multitech.com
You want to connect a voice circuit over a Canopy link using VoIP (Voice over Internet Protocol)? I’ve worked with VoIP equipment from MultiTech Systems (www.multitech.com) , but there are also other manufacturers to choose from.
Look in this forum for other threads discussing VoIP.
