Template "None" after applied?
Hi, after applying a template to an ePMP2000 AP in the Configuration tab the Template is in None, is that normal behaviour or I have some issue with my template?
Yes, that’s normal. That drop down box is not showing you what template(s) are applied, but rather the template(s) you can apply.
Also, if you want to check the history of what template you’ve applied you can go to the Detail tab. It will show the last three templates applied and if it was successful or failed.
All configurations applied can be seen in the Jobs page. On the left hand menu click Administration > Jobs.
Thanks, now I know that is working fine.
