We are going to install 60 deg. sector antenna to see how it works.
Hi Ramon,
Its unfortunate that the channel you have is the "cleanest" one. There are 12 other radios on or near the tower operating on that channel.
Have you tried 10 MHz channels? You can set ACS to run using 10 MHz channels.
Yes. Using a 60 degree antenna may help as well.
Sriram
