Transmission Limit On PTP500
 Good morning, I have the following query: We have a link made with PTP500 5.4 (52Mbps  License) conectorized with Ubiquiti Rocket Dish 30 Dbi, and the link distance between the two point is  55km. They were working properly, but from one moment to another, the latency rises up to 500ms, and then low . Another even bigger problem is that it never transmits more than 18Mbps symmetric, and the modulations never rise to more than 16QAM 0.50 (Dual) (15Mhz).
I attached an image of one radio for more details.
What does LINKPlanner say about this link's performance?
(You can download LINKPlanner for free here: http://www.cambiumnetworks.com/linkplanner)
I hope this helps!
Dave
Hey! Will you ook at that?
Our shortcut doesn't appear to be working right now...
You can download LINKPlanner (for free!) here: https://support.cambiumnetworks.com/files/linkplanner/
I hope this helps!
Dave
