Transmit power issue with a PTP400
We set the maximum transmission power to 25, but the web interface never shows a power greater than 22. This is true even when the receive power of the other unit is low (-90 dBm).
Any guesses on what the issue might be, or how I can get more detailed diagnostic information from the unit.
Thanks.
If you are using a freq at the edge of the band, I know it will not do 25 even though you have it set. That is how my ptp400 5.8 shows…Mine shows max at edge of 23…
We were using a freq on the very end. Moving it one channel towards the middle solved the issue. Thank you very much. :slight_smile:
