I have a failed XV2-2 unit which does not show any lights at all. I’ve already had it replaced under warranty and was told to dispose of the unit but I’m just trying to see if I can breathe any life into it at all. I’ve hooked up a USB UART adapter to the pins on the main board and I get a response. It dumps the following information to console before freezing. It stops at the same point every time.
I just wanted to see if there was any chance at all it can be reflashed or something like that? Is there perhaps a break sequence to get it to drop out of this boot?
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.XF.0.3-00077-IPQ60xxLZB-2
S - IMAGE_VARIANT_STRING=IPQ6018LA
S - OEM_IMAGE_VERSION_STRING=crm-ubuntu64
S - Boot Interface: SPI
S - Secure Boot: Off
S - Boot Config @ 0x000a602c = 0x000002e1
S - JTAG ID @ 0x000a607c = 0x0013a0e1
S - OEM ID @ 0x000a6080 = 0x00000000
S - OEM Config Row 0 @ 0x000a4188 = 0x0000000000000000
S - OEM Config Row 1 @ 0x000a4190 = 0x0000000000000000
S - Feature Config Row 0 @ 0x000a4130 = 0x0000000008000001
S - Feature Config Row 1 @ 0x000a4138 = 0x02c3e83383000009
S - PBL Patch Ver: 1
S - I-cache: On
S - D-cache: On
B - 3413 - PBL, Start
B - 592 - bootable_media_detect_entry, Start
B - 4339 - bootable_media_detect_success, Start
B - 4435 - elf_loader_entry, Start
B - 4607 - auth_hash_seg_entry, Start
B - 10853 - auth_hash_seg_exit, Start
B - 11349 - elf_segs_hash_verify_entry, Start
B - 383788 - elf_segs_hash_verify_exit, Start
B - 388215 - auth_xbl_sec_hash_seg_entry, Start
B - 388358 - auth_xbl_sec_hash_seg_exit, Start
B - 394902 - xbl_sec_segs_hash_verify_entry, Start
B - 394903 - xbl_sec_segs_hash_verify_exit, Start
B - 395832 - PBL, End
B - 316681 - SBL1, Start
B - 456707 - GCC [RstStat:0x0, RstDbg:0x600000] WDog Stat : 0x4
B - 459147 - clock_init, Start
D - 2745 - clock_init, Delta
B - 467626 - boot_flash_init, Start
D - 7991 - boot_flash_init, Delta
B - 478911 - sbl1_ddr_set_default_params, Start
D - 244 - sbl1_ddr_set_default_params, Delta
B - 485529 - boot_config_data_table_init, Start
D - 1921 - boot_config_data_table_init, Delta - (575 Bytes)
B - 494649 - CDT Version:2,Platform ID:8,Major ID:3,Minor ID:0,Subtype:0
B - 500200 - Image Load, Start
D - 6618 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B - 509533 - Image Load, Start
D - 5063 - PMIC Image Loaded, Delta - (0 Bytes)
B - 517402 - sbl1_ddr_set_params, Start
B - 522373 - CPR configuration: 0x366
B - 525576 - Pre_DDR_clock_init, Start
D - 183 - Pre_DDR_clock_init, Delta
D - 0 - sbl1_ddr_set_params, Delta
B - 562237 - Image Load, Start
D - 457 - APDP Image Loaded, Delta - (0 Bytes)
B - 575321 - Image Load, Start
D - 427 - QTI_MISC Image Loaded, Delta - (0 Bytes)
B - 577731 - Image Load, Start
D - 793 - Auth Metadata
D - 701 - Segments hash check
D - 28792 - QSEE Dev Config Image Loaded, Delta - (36354 Bytes)
B - 608505 - Image Load, Start
D - 6527 - Auth Metadata
D - 10644 - Segments hash check
D - 818895 - QSEE Image Loaded, Delta - (1470632 Bytes)
B - 1427857 - Image Load, Start
D - 763 - Auth Metadata
D - 1007 - Segments hash check
D - 63501 - RPM Image Loaded, Delta - (102664 Bytes)
B - 1493036 - Image Load, Start
D - 30 - Auth
