Hi all I have a 450m with UGPS not working any advice? A print screen with sync status from medua in the pic
Thank You
- ugps.png (10.3 KB)
Thank You
Hi beppeoro,
Can you provide some more info pls; what software load is running?
Has the connection from the 450m to the UGPS ever worked OK? If so, what changed?
If not, please describe in detail the wired connections between the 450m Aux port and the UGPS
Alternatively, please capture diags from the 450m (http://<IP Addr>/field_diags.cgi) and forward them to me
Thanks.
Bart
send it by email
I'll wait your answer before to climb the tower to change the UGPS
Thank you Giuseppe
