New to Cambium, but not to wireless…we just installed a PTP450 900MHz but wanted to confirm if you can set these up to use all the available bandwidth in either direction if the traffic flow allows for it?
Basically, is there anyway to configure these radios to allow all the upstream bandwidth if little is being used to download and visa versa?
It seems that “Frame Configuration: Downlink Data” sets DL speeds, but the percentage then locks the upstream to a bandwidth rate you can’t go over…I’ve never seen this limitation in a radio before.
