Hi, i noticed a low connection count at a HotSpot i'm experimenting with.
It uses Cambium's integrated DHCP+NAT
My original configuration, made manually, was as follows:
interface vlan 171
ip nat inside
management-access all
ip address 172.17.0.1 255.255.0.0
ntp server 200.20.186.75
ntp server 200.20.186.76
ip dhcp pool 7
address-range 172.17.0.10 172.17.255.245
default-router 172.17.0.1
dns-server 172.17.0.1
lease 33 22 11
network 172.17.0.0 255.255.0.0
The web interface showed a Pool-size of 235, so obviouslly something was assuming a /24 and subtracting 10-245 == 235.
I never saw any DHCP allocations to anything other than 172.17.0.X
Ignore the lease time, it's there for debbuging purposes. I was trying to force an exhaustion, to see what the logs would say. Unfortunatelly, not enough people passing by to trigger that.
So i decided to create an AP-Group / SSID and Site at Cnmaestro, and pushed that to the AP.
interface vlan 171
ip nat inside
no management-access
ip dhcp pool 7
address-range 172.217.1.1 172.217.218.219
default-router 172.217.0.1
dns-server 172.217.0.1
network 172.217.0.0 255.255.0.0
The pool never comes up, pool 7 shows as NA, and pool 1 (not existent), shows as DOWN.
Is this a known deficciency, or a bug, or i'm grossly misinterpreting the way the config should be done?
off course i don't need a /16 in the interface, the original production config was a /22 with 1 hour lease, or should have been....
Could anyone be kind and share a working config section for a non /24 Pool, so i can see what i'm doing wrong?
Hardware is an E700, firmware 3.11.2, rebooted between config changes to make sure interfaces were reloaded.
