We use radius for enforcing MIR this works fine but we would prefer that customers with lower signal get hit more than customers with good signals to incentivize our installers to ensure high modulations…
My question is if we just enable proportional on the AP side how does this work? What will happen, i set the default plan to 10/3 but we have plans over that still being sent from radius using the MIR settings…
As you can see above rate plans showing the default value from the AP, but the Sustaned datarate is showing the value from radius… so how is the schedule enforcing this kind of setup??? is it using the sustained rate or the rate plan?
We’re trying to avoid having to adjust all our packages to send additional plan informations… Also is it true from what i’m seeing theirs no way to set the lock modulation at the AP side? What happens if i want all SM’s to lock to 6x so that 8x/6x get great service but 4x/2x/1x get hit to their performance? I have to send the lock via radius to all SMs???
