Hi!
I am having issues with saving my projects. Everytime I open my project, the save button lits up, and when I push it i get the following error:
Unexpected errors (click for details)
Message
<ProductMode x1 (QPSK MIMO-A)>
Details:
Traceback (most recent call last):
File "link_planner\wxapp\main_frame.pyc", line 2872, in OnSaveProject
File "link_planner\wxapp\main_frame.pyc", line 2844, in _save_project
File "link_planner\wxapp\main_frame.pyc", line 2800, in do_save
File "link_planner\model\generic.pyc", line 3791, in save
File "link_planner\model\serialise\serialise.pyc", line 595, in save_project
File "link_planner\model\serialise\format_v2.pyc", line 1507, in save_project
File "link_planner\model\serialise\format_v2.pyc", line 1592, in serialise_project
File "genshi\core.pyc", line 184, in render
File "genshi\output.pyc", line 58, in encode
File "genshi\output.pyc", line 241, in __call__
File "genshi\output.pyc", line 669, in __call__
File "genshi\output.pyc", line 774, in __call__
File "genshi\output.pyc", line 594, in __call__
File "genshi\core.pyc", line 289, in _ensure
File "genshi\template\base.pyc", line 618, in _include
File "genshi\template\markup.pyc", line 326, in _match
File "genshi\template\base.pyc", line 558, in _flatten
File "genshi\template\directives.pyc", line 169, in _generate
File "genshi\template\base.pyc", line 289, in _eval_expr
File "genshi\template\eval.pyc", line 177, in evaluate
File "C:\Program Files\Cambium Networks\LINKPlanner\data_files\project.xml", line 394, in <Expression u'get_attrs(sm.link)'>
File "link_planner\model\serialise\common.pyc", line 110, in get_attribute_dict
KeyError: <ProductMode x1 (QPSK MIMO-A)>
So, I've found a solution which makes saving possible - I go to "PMP Links" in the project-tree, and i add the "SM Mod Mode Required" as a column. This seems to update all of the sm's, and I am able to save (read something about this in another thread on the forum, but this was related to an earlier release of LinkPlanner). Well - I am able to save when using this method - the only problem is that I have to do this everytime I open my project. Of course I do not have to save my project unless I've done any changes, but if I have made a change, or added anything, I am not able to save until I've been to the "PMP Links" in the project-tree (which I assume updates all sm's mod mode once more).
Is this a known issue to anyone, and in case - do anyone have a fix for this?
