Upgrading firmware on SMs.
I noticed that Prizm is not discovering new devices or SMs for new customers
under Discovered elements. I checked the software versions for the AP and the SM and it showed that they are different.
How can I upgrade the firmware of the SM when the AP is already updated using the 7.3… version and the SM is still on the 7.2.9 version.
thanks
Coco
2 ways - you can either upgrade the SM directly via CNUT, or use CNUT to turn AutoUpdate on in the AP (both require CNUT to have the firmware packages available to it).
Aaron
