After upgrading all my AP’s to 13.1.3 the uptime keeps resetting to 00:00:00 and starting over. I don’t seem to be losing connection to the AP’s and none of my client are complaining about disconnects. Is this a bug.
Equipment.
900MHZ Access Point
13.1.3 AP-DES
P10
Update:
I watched it reset. I had a constant ping to one of the AP and lost 6 pings in a row then saw the uptime reset. So it look like 13.1.3 is causing my AP’s to reboot.
I checked 5 AP’s on 3 different towers and they all rebooted about the same time.
Danny,
Can you contact our support center? We would like to get a CNUT capture of the APs that “appear” to be resetting. The CNUT capture will have the Event Log of the AP to understand what is going on.
You can contact our support center in three ways:
Phone:
http://www.cambiumnetworks.com/support/contact-support
Email: support@cambiumnetworks.com
Website:
http://www.cambiumnetworks.com/support/open-a-support-case
