Hello,
I was trying to create the following setup POP/DN (5000) ← V3000 - wired - second DN (5000). The second DN is too far from the POP/DN to make a reliable link itself, so I want to use a V3000 for the link between the two locations. I think this may end up being a common use case, as the distance between two DNs is about 400m and CNs in between could then connect to whichever was closest to them. I have a couple questions on this setup:
1: The V3000 and the second DN are setup in the topology as being at the same site. This automatically sets up a wired link between them in the topology. However, it is not clear which interface should be used on each device to connect them in this fashion, is there some default for this or some way to configure which interface should be used for this?
2: I am running a Layer 2 bridge on my setup, as I need IPv4 connectivity for my CPEs. In relation to the configuration outlined, can a local CPE be connected at the second DN site for local network connectivity at that site? Again the same question, which interface should be used for this to work, is there some way to configure this?
Thanks for any advice.
Des.
