Using force 200 to establish a bridge between two Lan
Over here we use mostly force 200 to establish an Enterprise network for client. It is use for both PMP and PTP to give organizations a dedicated line, Ethernet, lease line or data line.
Most times, the client (organizations) wants to maximize extend the usage by networking other locations to one gateway that come from the ISP.
Can we use Cambium force 200 to act as a bridge or a Carrier of internet from one building to another with a distance of over 1KM?
Hello Alex,
yes, for sure you can use the ePMP Force 200 to form a short range point to point link.
But, it is interesting to build a private point to point and point to multipoint solutions to connect multiple sites to internet from a single main location. This way, you can handle your capacity and monitor your networks as well.
But, depending on the capacity and range of the link, I can advise you to explore the PTP 670, PTP 550 radios too.
Let me know if you need any other assistance.
Sincerely yours,
Niragira Olympe
Am so grateful for your response. How do I build a private point to point or point to multipoint?
Do I need another device to do that?
Hello Alex,
yes to achieve a point to multipoint, you need an Access point (ePMP 2000/3000 or PMP 450i AP) and some subscriber modules at the client sites or secondary sites like the ePMP Force 200/300 that connect to ePMP APs or PMP 450i/450b that connect to PMP 450i AP.
Let me know if you need to achieve this point to multipoint too.
Sincerely yours,
Niragira Olympe
