Using Repeaters with T1/E1 Multiplexer?
When using the new T1/E1 Multiplexer on an end-to-end link, is it ok to have a repeater present in the link? If so how many repeaters may you have?
We haven’t tested maximum repeaters but in theory you should be able to use as many as your application will allow. If you are using voice and each repeater adds a few ms delay then you will eventually max out.
