Hi there,
I am currently doing a deployment with 1x V5000 as POP and 2x V3000 as DN …
Link is stable with MCS12 up and everything works for 5-10 minutes. However, after 5-10 minutes I lose connectivity to the V5000. It cannot be reached via the local network (wired) or via the radio link. (no ping / no GUI / …)
After a power-off / power-up, the V5000 works again for 5-10 minutes - and then it cannot be reached again.
- V5000 is powered via POE-Injector.
- 2 different POE Injector tested
- Cable Length ~25m CAT-7
Anyone have any ideas about this problem?
Thank you, best regards from Tyrol
Andreas S.
