Hi there,
we have a setup with 1x v5000 to 2x V3000 connect (Sector A & B). The link is stable up with MCS12. Connection via Layer-2 Bridge (IPv4 Traffic).
What are the realistic expected net bandwidth values?
I currently have an iperf running in both directions and get between 1.1 - 1.2 GBits. Is that the maximum or can we get a little bit more bandwith out of the Link?
~ 1.7 Gbps in each direction in your configuration, test run is expected.
Could you please click on Download statistics button (while test is going on) and send the downloaded csv. Whats the iperf command you are using ? Whats the iperf version ?
