I recently upgrade my SM from 7.3.6 to 8.1.4 then to 8.1.5.1.
Its registered to an Advantage AP version 7.3.6.
The issue I am seeing, the sm locks up every so often. I am still able to login in to the sm. The only way to resolve the problem is to reboot the SM.
Has anyone experienced this before any ideas on how to permanent resolution.
I’ve seen this problem too, i’m able to get to the first page, but i just can’t login. SOmetimes it happens while gaining access from the SM and sometimes from the ip address of the SM. Haven’t seen a solution yet.
I saw this problem as well when testing the beta versions for v8. The only solution I found was to run matching firmware in both APs and SMs. I believe this is also a recommended practice by Motorola.
Aaron
