What should be the vertical distance between AP and SM in a Remote Access Point in case of modules operates on adjacent channels and both are directed to the same side?
kaa wrote: adjacent channels
Are you saying that you are using a SM to feed an AP at a remote location and the SM you are using as you uplink is the same frequency range as the AP you are feeding?
IE: 2.4 SM feeding a 2.4 AP
Yes, the SM is 5300 and the AP is 5280.
Cluster1 Cluster2
AP 5300 <-------------> SM 5300 - AP 5280
The APs are directed to each other.
same band at least 100 vertical ft.
How much can I reduce the distanse by using a reflector for the SM and some kind of shield between the SM and the AP?
