vlan gateways and guest issue
Hello all  I am new to cambium and  have a question regarding configuration on CNMaestro and APs .
I have deployed WIFI network using cnMaestro cloud.
I am using 15 cnPilot425e APs and 2 cnPilot505e APs.
All the cnPilot425e are in an AP group called indoor and all of the cnPilot505e in AP group called outdoor.
I am using a VLAN for management and enterprise (VLAN1), and A (VLAN200) for guest access through cnMaestro guest portal using VOUCHERS.
On all access points I have configures for VLAN1 static IP address through APs configuration on a network 192.168.11.0/24 and for VLAN 200 I am using my routers DHCP for 192.168.80.0/20.
The DCHP server for both network (VLAN1 and VLAN200) clients is located on a third-party router.
When I am checking   cnMaestro tab, AP GROUP INDOOR->APNAME->DETAILS->NETWORK INFO
I see the following table on IPV4 routes :
0.0.0.0                 0.0.0.0                   192.168.11.1       UG     0    VLAN1
169.254.0.0      255.255.0.0          0.0.0.0                    U       0     VLAN1
192.168.11.0   255.255.255.0      0.0.0.0                   U        0    VLAN1
192.168.80.0   255.255.240.0      0.0.0.0                   U        0    VLAN200
  • I am facing a problem with VLAN200 when the internet connection disconnects even for a short period 1-2 minutes the clients on VLAN1 do not even notice the disconnection but clients on VLAN200 are getting in the mobile devices a message no internet connection even for 25 minutes period. Why is that happening.
  • The above IPV4 route table means that both networks are using as a gateway the 192.168.11.1? If this is the case can I configure the network 192.168.80.0/20 to use another route/gateway for internet?
Hi gkourm,
I recommend cross-posting this on the cnPilot Enterprise forum as well to increase visibility since this deals with a combination of cnPilot Enterprise and cnMaestro.
https://community.cambiumnetworks.com/t5/cnPilot-E-Series-Enterprise-APs/bd-p/cnPilot_Indoor
