I have searched the forums, and found links to guides that no longer exist. I have read the manual pp 169-170, pp 249-252, and pp 282-285. But I am still confused. The VLAN concept is familiar to me: append an ID and devices with the same ID are in the same VLAN. But how does Canopy really work?
- I do not understand the Management ID. What is this, and why do I get locked out locally if this is changed?
- Can the front-end of the SM be on a separate VLAN from the backend (wireless port vs ethernet)?
- I want to be able to get to the user interface locally (a tech support person) and on the admin network. But the tech does not want to carry around a switch capable of VLAN. How do I get around this?
- I want SMs available on the network by admins. This seems possible with a VLAN.
- I want the SMs isolated. While this could be done with VLAN, it sounds like it is easier to use SM isolation on the AP. However, one or two SMs should be able to to get into everyone’s SMs (tech support).
- Almost all the APs are connected via CMMs, but one links to an SM with a sync cable. How would this work?
- I have Redline, Dragonwave, Memorylink, Last Mile Gear, (and something else) products used for backhauls that I want on the VLAN. I do not see VLAN configuration for each of these devices. What are my options (throw them on a switch, can the CMM handle it, etc)?
Thank you for assistance. A link to a good guide would be very helpful. I realize this is all probably basic, but I am not getting how to properly create VLANs that accommodate the ethernet vs wireless ports on these devices.
