VLAN settings
I am testing VLAN settings in SMs and APs in a test environment. I am having no luck at all getting this to work. Anybody else out there got this working yet?
Yes, i’ve got it working…
But how can I prevent users from sending packets with VLAN ID set by non-Canopy equipment?
Without this possibility users can spoof VID’s with other subscribers VID’s.
Jaybug56, check if “Configuration Source” is set to “SM”.
I have a problem with “Untagged Ingress VID” settings on SM.
I’m setup “Untagged Ingress VID” to 2310, then reboot SM.
After Reboot i can see 2310 in “Untagged Ingress VID”. But “Active Configuration” table shows me "Untagged Ingress VID : 1"
I havn’t got working SM with untagged frames from my computers (general nic without vlan tagging support).
See image:
http://pavelsh.pp.ru/canopy.jpg
pavelsh, check if “Configuration Source” in AP configuration screen is set to “SM”.
Eric wrote:
pavelsh, check if "Configuration Source" in AP configuration screen is set to "SM".
Yes. I solve my problem after previous posting.:)
Thanks for help.
