Hi
Would be cool to be able to create multiple VPN IPsec & PPTP VPNs that can be enabled / operational similtanously.
Another thing that would be great would be to be able to schedule a reboot without needing to do a reboot to save the fact you want to do a reboot later on in the day. Seems odd you need to do a reboot to do a reboot.
Port forwarding doesn't work at the momemnt. You can use the public IP Address with a port number that then forwards to a device on the internal network but you cannot do multiple ports going to the same device.
Adding these features would really go towards making the cnPilot R201 a great router for the SMB market place.
