actually almost 10 now.
when i go to do a spec analyzer it reads -100 all the way. no movement AT ALL.
tried a new ant, nothing, replaced SM with a new ones and it all looks good.
is this a bad radio? the $$$ is starting to add up, if you know i mean
the_NAT wrote: actually almost 10 now.
is this a bad radio? the $$$ is starting to add up, if you know i mean :)
This sounds like the P10 issue... they should be able to be RMA'ed still...
-forrest
we have had several 5.7 sm’s that have gone “Deaf” after a few months. installed in the high -50s and slowly degenarate to -79 then not work. swapped in a new Sm -57 solid.
