What does this mean?
The unit is configured for None, but the network has overridden it to United States.
What product are you seeing this on?
Canopy pmp 5ghz. Just popped up on one of the installers radio as he was programming
I’m assuming you’re seeing this on an SM that’s connecting to an AP that has it’s region set to United Sites?
Typically, the SM’s region follows the AP it’s connecting. So if the SM region is ‘none’ and it connects to an AP with region ‘United States’, then it will display that message.
Yes you are correct. Thank you for that info
