we are currently starting our tests of EPMP3000 in the "real world". Just deployed a new tower with 3 x EPMP3000 with smart antennas.
We have set 80 MHz channels on the 3 AP, on all of them the spectrun is quite clean.
We are testing using F300-25.
What we see is that when we set F300 in NAT mode, speed tests on OOKLA never go over 25-30 Mbps, while Cambium Speedtests between AP and F300 perform over 2-300 Mbps.
In the same conditions If we set F300 in Bridge mode speed tests on OOKLA perform 60-80 Mbps.
We will make more tests in the next days. We would like to have results from other people testing new EPMP3000 and F300. What results are you having? Also, are you experiencing any speed problem with NAT on F300?
could you tell me exactly what kind of the issue are you experiencing? This tread is 4 year old and we run CI/CD. This means all issues were sorted but we could get new ones.
