What should I do if I dont have an Ethernet Link light on my OFDM BH Power IDU?
Solution:
Check CAT5e cable to verify wired as straight through.
Try swapping out PIDU to rule out PIDU.
Try swapping out cable with known good cable.
What do you see on the PIDU LED's (power-Led solid green which is normal or something else?if flashing disconnect power). Ethernet LED/ should flash 10 times on startup to indicate the correct startup sequence has occurred and then go solid amber.
