When would I need to use a reflector with my SM?
An SM reflector would be required for links that are over 2 miles unless you are using 2.4GHZ then you would need a reflector for links over 5 miles.
Also remember that use of reflectors in the 5.2 GHz band is against FCC regulations. Only use reflectors on bands other than 5.2 GHz.
