which kind of Power Amplifier is using in PTP650 ? is there any information
Why do you need to know this? I really doubt that they're going to tell you this. Are you just wanting to know the max TX power per port or something?
Hi… just share if you have… we need to know for FCC rules only…
I don't know what kind of amplifier they're using. Additionally, knowing what kind of amplifier is in the PTP650 isn't relevant to anything I can think of in regards to being compliant with FCC EIRP rules, which is what I assume you're trying to figure out. What is relevant is knowing the TX power output is so you can be FCC EIRP compliant. Why don't you just download and read the PTP650 specification sheet or read the manual?
