while using 4(90 degree sector)antenna in PMP450,
Do I need 4 seperate PMP450 for 4 sector antenna?
or just 1 PMP450 will be needed for 4 antennas?
You will need one AP module for each sector antenna.
can you please give a rhough estimated quotation for four sector antennas and pmp450 acces point module.
Hey Adiviance, go check out Cambium's PMP450 product page, and press the 'Request a quote' button and fill in the information to have Cambium connect you with a regional sales manager (RSM).
Just to reiterate what Ray said... you will need (4) AP's and (4) sector antennas, along with the required accessories, like RF cables, and PoE's, lightning protection, and possibly a CMM if you're wanting to use back to back frequency reuse. These are all things that a RSM will help you figure out and put a bill of materials (BOM) together for you, along with recommending you to a distributor or VAR close to you.
thanks eric
you have been of great help
Quite easy, the AP have 2 connectors and the sector antenna has also 2 connectors :)
Anyway, which antenas do You want to use ?
