Wifi Client Signal Levels on R200
Hi
Can anyone tell me how to view the client signal levels on the R200.
If a customer calls up saying they have internet problems, we can usually log into their ubiquiti router and see the signal level in -db for each wifi device and usually its a case of saying "that ipad is too far from the router" but I cant see where the signal levels are for wifi clients on the R200 units we have been installing
Am I missing something?
You can check the client RSSI levels in cnMaestro, under Monitor->Tools in the Client Health tab
Okay but what about the router interface? Not all our R200 routers are connected to cnmaestro
Also I find that cnmaestro takes a while to update values
