I would like to use captive portal generated in cnMaestro On Premises. The setup is working quite well, but there is a problem with adding the required snippet. I searched through related documents and in this forum, but I didn't find any description how to implement it (the easy way) on the local installation (On Premises). It seems, that I am missing some configuration settings which are present in the cloud version. Is there a way how to solve it?
Hi ,
WiFi4EU is currently only supported on cloud. In On premises it will be available in next cnMaestro release 2.3.0
KR.
