Does anyone have information on the wind-loading figures for any of the range of antennas? I am planning a mast deployment with at least 2 x PTP antennas, and 3 x sectorised antennas for a PtMP solution, and need some figures to be able to specify the mast correctly.
Thanks in anticipation…
David Grenfell
David,
Wind loading figures can be found in the User Guides available from our website. For example, if you have a PTP 600, you can go here to get documentation : https://support.cambiumnetworks.com/files/ptp600
