Nearly all of a network administrator’s time is spent monitoring and configuring edge devices. With Wi-Fi as the network access mechanism, the ability to easily and cost-effectively administer a unified wired and wireless network edge is a requirement. cnMatrix with its customized and flexible wireless-aware support is designed to expertly satisfy this need.
Check out the Solution paper attached
- SP_cnMatrix_wirelessAware_06142019.pdf (2.76 MB)
