since the last Update to SP2 i miss some OID when i create a configuration template?
for example:
with the WLM Version 3.0.19 + SP1 i can set the option
Networkconfiguration->Firewall setting->ether-type Filter->PPPoe Enable/Disable
After the upgrade i can’t find this option anymore
Any Idea
P.S. Thanks to Motorola. Great Job.
Hi everyone,
i have found the OID in the Template files on the server. I dont know why it is not displayed in WLM
.1.3.6.1.4.1.10529.300.9.19.0
Maybe
P.S. Great Moto
