Dear All,
I Have Wireless Manager 4.0 & not able to run spectrum analyzer from WM.
I am using canopy PMP 100
V11.2
Can anybody knows why is that happening???
I don’t know why but we have the same issue.
Actually WM does run SA it just does not display it. If you run SA then open web page>tools you will see the current SA display. I just run it from the browser.
Steve
Dear steave
I know we can run SA from device.
but if we have an option in WM then, it should work.
we have done some testing regarding this issue & we found that this SA runs only for 11.0/11.1 software versions.
I think patch/SP upgrade is required.
Satish
